Thermal Conductivity of Bunker C Fuel Oil (Fuel Oil #6)
thread481-196761
Good Day Everyone,
I am currently using Bunker C Fuel Oil in the design of a heat exchanger, but I cannot seem to find a reliable value for the thermal conductivity of Bunker C. The Bunker C is being heated from 100°F (at the inlet) to 140°F (at the outlet); this is the temperature range that I am looking at.
I understand that the properties of Bunker C vary depending on the location it was taken from, but I am hoping that there may be a consensus on what thermal conductivity should be used.
If anyone has any data regarding the thermal conductivity of Bunker C Fuel Oil and can provide references for that data, it would be greatly appreciated if you could provide me with this information.
Mech011
Good Day Everyone,
Mech011
RE: Thermal Conductivity of Bunker C Fuel Oil (Fuel Oil #6)
The spanish version of Perry VI brings FIG. 9-6 showing the thermal conductivity of liquid petroleum-derived fuels as function of density and temperature.
Same graph appears in Perry VIII in FIG. 24-2.
The solid lines refer to oAPI; the broken lines refer to relative density at 15oC.
What are the Chapter names for 9 and 24 in the 6th edition? I have 7th edition and 9 is Process Economics and 24 is Biochemical Engineering.
Chapter (sección) 9 of the 6th spanish edition is titled:
Utilización, conversión y conservación de los recursos energéticos.
Mech011, your turn.
rmw
Chapter 24: Process Machinery Drives
