Conversion of lbs/in to N/mm
Hey guys, got a test result back and they gave it in lbs/in and I need it in N/mm as the requirement states. This is a breaking strength test for fabrics. I'm having a little trouble converting this, could anyone help me out? It is 88lbs/in
RE: Conversion of lbs/in to N/mm
Mike
BTW, units are never pluralized; e.g., 'lbs' is a no-no.
And 1 in = 25.4 mm.
Using unit cancellation from lb/in to N/mm gives you a factor of 4.448222/25.4 or 0.1751268
I use this conversion freeware program:
http://joshmadison.com/convert-for-windows/
Thanks for taking care of that for me :)
