material A216 WCB for gate valve.
Greetings to all
Can I use the ASTM material A216/WCB to a gate valve globe-8 "
# 150?. piping system fire has an operating pressure 100-120 psi
room temperature. Does anyone know where to find the specification for the selection of best material for the gate valve globe?.
RE: material A216 WCB for gate valve.
The ASTM or similar ASME material A216/WCB likely applies to the body and flange material for a carbon steel gate valve. The standard applies to the valve bodies, flanges, some fittings and other pressure-containing parts. Tables related to the flange class may apply to the pressure and temperature rating. The ASTM standard applies to service and assembly etc. Other casting and steel parts are related. Such valves may be associated with other grades such as WCA, WCB, and WCC. Good control valves have mostly moved from WCB to WCC. Each grade is covered in the codes and standards. Check to verify that the selection is suitable to the process conditions including temperature etc. Other information helps to verify the material requirements.
