Sap API Visual Basic Trusses
I currently have a sapIV text file that I wish to put into SAP2000 using Visual Basic and API.  Sap2000 however does not have the 3D truss members that SAPIV did.
I need a way to automatically create trusses in a structure that has both trusses and frames.  I have tried releasing the moments on frame members by creating a group called "trusses" and then releasing the moment restraints on either end with the following
               'Release Moments on Both Ends
                For k = 0 To 5
                    ii(k) = False
                    jj(k) = False
                    StartValue(k) = 0
                    endvalue(k) = 0
                Next
                ii(3) = True
                ii(4) = True
                ii(5) = True
                jj(3) = True
                jj(4) = True
                jj(5) = True
                ret = SapModel.FrameObj.SetReleases("Trusses", ii, jj, StartValue, endvalue)
It doesn't seem to do the trick...any thoughts?
RE: Sap API Visual Basic Trusses
Hi.
What if you try:
ret = SapModel.FrameObj.SetReleases("Trusses", ii, jj, StartValue, endvalue, 1)
The one at the end tells SAP200 that "Trusses" is a group.
