Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Keep up the very good job that you and your team are doing. This site has replaced my morning cup of tea as a must have/do!!!..."
Geography
JulienRacca (Industrial)
25 May 11 15:42
I'm looking for a rubber press pad/slab in order to apply uniform pressure in a pneumatic wakeboard press where "3d top" surface composite wakeboard are pressed. We press @ 50psi, 70C and 3D relief is about 1/4" deep. What type, thikness and hardness of rubber will work for this purpose? The rubber must be soft enough to fit the 3D surface and hard enough to push out excess resin. Any idea? thanks
Compositepro (Chemical)
27 May 11 21:31
A rubber pad will not apply uniform pressure. An air-filled bladder will.
29 May 11 9:17
Thank you for your reply Compositepro. We already use an air-filled bladder to apply pressure in our setup but the bladder do not push directly on the board (our bladder will not support 70C and the composite must be heated from both the bottom and the top). In fact, we are looking for a pad (silicone or neoprene?) to compensate for the little relief of the top side of the boards. The pad must rebond for multiple application. Another possiblity is to make a female mold (urethane shore 80-100A) but accurate positioning will be a challenge.
here is a detail of our setup (from bottom to top):
-Bottom mold
-heating element (silicone blanket)
-alu plate
-wakeboard
-Pad? female mold urethane? 1/2" thick
-alu plate
-insulation
-bladder
-top mold
Close Box
Join Eng-Tips® Today!
Join Us             Close
