PDM and revision managment
first off
I am currently moving a range products that have been badly managed by the drawing office in autocad to solidworks. And redrawing the parts and assemblies to make sure what is drawn is what we get supplied.
I am wondering if it would be best practice to up issue the redrawn parts one revision and send them to the suppliers so that we are are working from the same sheet.
Has anybody managed to set, PDM to link and engineering change request number to a revision so that one engineering change request can be used on mutiple parts/ assembly that are affected by it? Is this gonna a case of coding a VBA Form up to manage this?
Can the data for the change request e.g reason who requested affected drawing and who checked off the drawings be held in the PDM data base? Again is this gonna a case of coding a VBA Form up to manage this?
Or would it have to be an excel sheet? Also How do I set up an auto number facilty so that each time an new part is created it uses the next drawing number available in sequence so it can be used as a primary data base key.
What is the recommend way to store the drawing part assembly template for mutiple users? vault?
Is there a way of setting up the drawings so there is a not for prodution banner on it until it has been checked off and checked into the vault for to be released for production?
Also part configurations and PDM is it worth it? I.E have several drawing of part linked to one part model?
I am asking these questions because I used a different system that did all this.
RE: PDM and revision managment
Matt Lorono, CSWP
Lorono's SolidWorks Resources & SolidWorks Legion
Follow me on Twitter
Why not just add an ECR column to your revision table?
"What is the recommend way to store the drawing part assembly template for mutiple users? vault?"
Yes, if everyone has a PDM viewer. If not, save copies (PDFs etc...) to a common location on a server.
"Is there a way of setting up the drawings so there is a not for prodution banner on it until it has been checked off and checked into the vault for to be released for production?"
Do some research into 'lifecycles' in PDMworks.
If you do some digging around I think a lot of your questions may already be answered in this forum.
Cheers,
Simon
