Section views in drawings
Hi all,
I created a section cut in my assembly to show internal parts and then save the configuration. Is there a way to call up that configuration in the drawing to display the section cut or do I have to recreate the cut in the drawing?
Thanks!
Joel
Thanks!
Joel
RE: Section views in drawings
In 19 you can call up configurations in views (right click on view, properties, at the bottom of the second tab) however it basically only controls what items are shown/hidden.
So no I dont' think you can do what you're asking, at least in the versions I've used.
However, sections are very easy to do in draft.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Right click on the view, and select properties.
Click on the sections tab under properties, and place a check in the box of the approperiate section you wish to show in the view.
Update, and your sectioned view should not show.
-av8errr
Solid Edge ST3
xw46003GB
RAM2Quad CPU
3.00GHz
I'm still learning (and forgetting and learning again) new ways to accomplish what I need to get done in Solid Edge.
-av8errr
Solid Edge ST3
xw46003GB
RAM2Quad CPU
3.00GHz
