Zipping all parts of an assembly
Hi all,
I am looking to zip all parts of an assembly into a single file that can then be sent to the customer for review. Is there a way to do this in Solid Edge ST2?
Thanks!
Joel
Thanks!
Joel
RE: Zipping all parts of an assembly
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
You might need to set some of the create options.
Go to Tools > Options then on the View and Markup tab check the boxes for "Store Precise geometry in file" and "Enable Measure, Markup & sectioning"
They can then open the pcf file in view and markup and you haven't given away any intelligent data.
They can also add markups and send the pcf back to you.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
There is a free german macro from a german company it's called hitteam tools.
It is the same like pack & go for autodesk products.
Dirk
http://www.hitteamtools.com/activePach2Go.html
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
This forum rocks!! It is people like all of you that make it easy to learn new software packages.
I use this alot with a SW client and it works very well. If your client is a Solid Edge user on ST2/3 then often the only drawback is the loss of assembly relationships. But for review this is rarely an issue.
Tony
It has worked well for me in the past.
-av8errr
Solid Edge ST3
xw46003GB
RAM2Quad CPU
3.00GHz
