NX6 Drafting - Internal error: memory access violation
NX 6.0.3.6
Windows 7 Professional - 64bit
8GB RAM
I keep running into the same problem when I enter drafting. The Drafting Sheet dialog displays, I make my selections, and hit OK/Apply. The result is "Internal error: memory access violation".
It doesn't happen all the time, but it does happen more often then not. I checked the NX Log File and found the following information.
*** EXCEPTION: O/S ERROR: signal 11 in line 1686 of O:\ugnx603\ip6\src\syss\error\ind\error.cxx at Tue May 24 20:10:53 2011 Eastern Daylight Time
+++ General Fault Exception
>>>> O/S ERROR: signal 11 caught in file "O:\ugnx603\ip6\drv\part\no\ind\ja_builder_jam.cxx" at line number 107
>>>> O/S ERROR: signal 11 caught in file "O:\ugnx603\ip6\src\uifw\no\ind\uifw_definitions.c" at line number 1815
&MACRO FOCUS CHANGE IN 1
&MACRO MESSAGE_BOX -2, Internal error: memory access violation
&MACRO EVENT FOCUS_IN 0 0, 7602176, 1, 0, 0! 3rd Angle Projection
&MACRO ASK_ITEM 7602176 (1 RADI 0) = 1 ! 3rd Angle Projection
&MACRO MENU, 0, UG_HELP_SYSTEM_LOG UG_GATEWAY_MAIN_MENUBAR !
I have to wonder if I'm missing an environmental variable or a definition setting that would fix this. If anybody could point me in the right direction, it would be greatly appreciated.
8GB RAM
John B. Conger
Tool Design
Automotive Interiors
Advanced Engineering Solutions Inc.
http://www.advancedinternational.com/
RE: NX6 Drafting - Internal error: memory access violation
I would recommend updating to the NX6.0.5.3 MR and see if that fixes it first.
Anthony Galante
Senior Support Engineer
NX4.0.4MP10, NX5.0.0->5.0.6, NX6.0.0->NX6.0.5, NX7.0.0->NX7.0.1 & NX7.5.0.32-> NX7.5.2.5, Beta NX8.0.0.15
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
John B. Conger
Tool Design
