Double Volute Casing Drain Hole [API610]
I have a somewhat large API610 OH2 pump with a double volute.  This pump is holding crude in the "inner" volute because it does not get a chance to drain.  The hole drilled through this "inner" volute (connecting the two volutes for drainage purposes) is drilled at 1/8" and keeps clogging.  Does anyone know if API specifies what size this hole should be?  1/8" seems somewhat small.  I hope this was clear.  Thanks for your help!
RE: Double Volute Casing Drain Hole [API610]
You did not mention what size the pump is.  But, based on the comparable pumps that I have overhauled, I would expect this hole to be at least 1/4" or 3/8".  You are correct.  A 1/8" hole is too small (especially for crude service).
Johnny Pellin
API 610 does not specifiy the size of drain holes.  It only asks for the pump to be as self draining as is practical.
The general use of 1/8" is because elsewhere in API 610, size of orifices is limited to 1/8" or larger.
A 1/4" or larger hole will have no effect on the performance unless you get too ambitious with your drill.
