Laptop requirements
Laptop requirements
Hi!
What reqs should a laptop have to be able to run NX7.5 without any problems?
RE: Laptop requirements
- Buy the most expensive ( high spec) one that you can afford, no less than 4 Gb ram if you are going 32bit OS. No less than 8 Gb on 64bit.
Certification list for NX, you have to continue select from this page:
htt
Do not try a non certified laptop*, the chance that you will have to spend hours and days chasing strange graphics problems is major, and Siemens will not help since it isn't certified. * unless it is a new model about to become certified shortly, or you can return it if it does have graphics problems.
Dual-core or quad-core processors have a penalty to pay, though they do have advantages. Few NX operations take advantage of multiple cores. The advantage is that NX can be run on one core and other cores do your other processing. Multi-core has a performance hit in managing the multi-cores.
FX graphics is a must and you may have to play with drivers. The certified drivers are usually not the latest, but the latest ones may be better. The drivers are free, so play around if your performance isn't what you think it should be.
Ben Loosli
