New to Journals, Macro User Entry Equivalent?
Running Windows XP Pro 32Bit  NX 7.5.3
I'm just starting using Journals as opposed to macros, and I want to be able to edit a dimension from a dialog box like I would do with a macro.
In a macro I would select the feature, then the dialog box would come up, and I would insert User Entry or User entry with instructions.
What is the equivalent within a Journal?  If I have to enter code to get it to do this, can someone give me an example of it?
RE: New to Journals, Macro User Entry Equivalent?
Attached is a pdf document which for totally new users in modifying journals may be of some help.  This only gives an introduction to editing journals by showing the changes to a simple journal for creating an arc.  The modifications decribed and shown in the modified journal include radius entry, centre point selection and journal flow control.
Hope this is of some help.
Frank Swinkels
I think it is not very useful to record a journal to edit feature dimensions and then somehow make this journal useful.  It is simpler to write the code.  Below is a fairly simple program to edit the feature expressions.
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Imports NXOpen.Features
Imports NXOpen.Utilities
Module EditFeature1
 Dim theSession As Session = Session.GetSession()
 Dim ufs As UFSession = UFSession.GetUFSession()
 Dim ui As UI = UI.GetUI()
 Sub Main()
  Dim response As Selection.Response
  Dim feat As Feature = Nothing
  Dim exp As Expression = Nothing
  Dim noExps As Integer = Nothing
  Dim expdescstrings(-1) As String
  Dim exptags(-1) As Tag
  Dim expValue As String
  Dim expTitle As String
  Dim expvaluenew As Double
  Dim nErrs1 As Integer
  Dim id1 As Session.UndoMarkId
Start1:
  response = select_feature(feat)
  If response = Selection.Response.Cancel Then GoTo End1
  ufs.Modl.AskExpDescOfFeat(feat.Tag, noExps, expdescstrings, _
                            exptags)
  For i As Integer = 0 To noExps - 1
   exp = NXObjectManager.Get(exptags(i))
   expValue = exp.RightHandSide
   expTitle = exp.Name
   Try
    expvaluenew = NXInputBox.GetInputNumber("Enter Exp Value", _
                                  expTitle & " = " & expValue, _
                                  expValue.ToString)
    exp.RightHandSide = expvaluenew.ToString
   Catch ex As Exception
     GoTo Continue1
   End Try
  Next
Continue1:
  nErrs1 = theSession.UpdateManager.DoUpdate(id1)
  GoTo Start1
End1:
End Sub
Public Function select_feature(ByRef feat As Feature) As Selection.Response
  Dim selobj As NXObject = Nothing
  Dim cursor As Point3d
  Dim typeArray() As Selection.SelectionType = _
         {Selection.SelectionType.Features}
  Dim resp As Selection.Response = _
     ui.SelectionManager.SelectObject("Select feature", _
     "Select feature", Selection.SelectionScope.WorkPart, _
      False, typeArray, selobj, cursor)
  If ((resp = Selection.Response.ObjectSelected) _
    OrElse (resp = Selection.Response.ObjectSelectedByName)) Then
    feat = CType(selobj, Feature)
   Return Selection.Response.Ok
  Else
   Return Selection.Response.Cancel
  End If
 End Function
End Module
Hope this helps
Frank Swinkels
Thank you Frank,
I am looking thru this, but so far, that 2nd post is very useful.  I want to create some journals that rely only on the user entering in dimensions of a few critical dimensions
Thanks again
