Nested Repeat Region?
I have a BOM table with a repeat region that list all the items in the top level assembly.
It shows the components Det#, Sht#, Qty, Matl, Descr, and Treatment parameters in separate columns.
The table also has a nested repeat region so the main BOM can also display the components in the sub assemblies. Our sub assemblies are normally just welded structures.
I was wondering if it is possible to nest another region inside those nested repeat regions in order to display the any sub, sub assemblies.
ASM, (main region)
- subasm (nested region)
- subasm (nested nested region?)
If possible, can you give me a step by step how. I've always had a hell of a time creating regions.
ASM, (main region)
RE: Nested Repeat Region?
Thanks!
One training example is a robotic arm that changes from a welding torch attachment to a gripping attachment.
Ben Loosli
