Max. rebar spacing in masnory
I am designing an interior masonry wall for some lateral load and I have determined that I need very little rebar. Is there a maximum rebar spacing limitation in the code somewhere, because I would like to place the bars @ 72" oc but I have noticed that most engineers tend to place the bars not farther then 48".
RE: Max. rebar spacing in masnory
The MSJC (ACI 530,etc.) has a requirement that the maximum "flange" width in bending in a wall is limited by bar spacing, 72" or six 6) times the wall thickness.
With typical 8" thick wall, that would put your effective B at 6x8 = 48". So going beyond 48" you are not getting any additional flange width help. Not a huge deal but consider it.
Also, section 1.17 has numerous requirements for minimum reinforcement in various seismic conditions.
Dick
Engineer and international traveler interested in construction techniques, problems and proper design.
I beleive a 6" wall is more practical for something non-bearing as this is and could be reinforced if desired.
Dick
