gearbox vibration monitoring
A supplier has suggested that permanently mounted vibration sensors should be attached to the baseplate.
I think they should be mounted higher up on the gearbox to a rugged feature like a bearing boss.
Comments?
thanks
Dan T
Comments?
thanks
Dan T
RE: gearbox vibration monitoring
And I agree that the two locations are just looking at overall vibe levels. You will probably have a hard time catching a failure in the beginning stages, but at some point it will get bad enough! Depends on what you need and/or want.
ISZ
