Position Bonus/MMC, Cpk, and Inspection Results, Nominal Geometry
I am interested in using statistical tolerancing on upcoming projects, but I am not sure what the Cpk will be based on if the 'size' nominal is not the same as the 'form' nominal if I use bonus tolerance. Is there a formula that averages the two or weighs them? Is it correct to say that 'form' is the area between the Virtual and Resultant conditions?
Since more and more software is using the CAD model for machining and inspection, should nominal CAD geometry be established at the nominal form geometry or at the nominal size geometry when using the MMC modifier on holes and similar features such as slots?
As others have said on another thread, 'position' information is often not reported on inspection reports. But if it is, is there a yes/no indication that the 'size' measured was allowed given the measured 'position'?
I prefer using profile call-outs whenever possible to keep my nominal size and form the same, but some of my suppliers are not comfortable with 'profile', so I need to figure out how MMC works with statistical tolerancing.
Peter Truitt
Minnesota
RE: Position Bonus/MMC, Cpk, and Inspection Results, Nominal Geometry
Have you tried this as an introduction to the topic?
http://www.tec-ease.com/gdt-tips-view.php?q=95
http://www.tec-ease.com/gdt-tips-view.php?q=172
http://www.tec-ease.com/gdt-tips-view.php?q=180
Peter Truitt
Minnesota
Peter Truitt
Minnesota
In my opinion, the whole notion of statistics and capability studies flies in the face of the philosophy of the MMC modifier. If you use the "M" you are saying that slop is OK, right? So why the requirement to monitor statistics, as if it were a critical fit? Just my two cents...
John-Paul Belanger
Geometric Learning Systems
See this presentation.
Paul
One cannot figure out the bonus tolerance and then apply it to the centre of the feature in addition to the tolerance stated in the FCF as we once did. Most of the time when a company was forced into providing capability studies on positional tolerances at MMC on features of size, it was not done correctly. The data of faked just to achieve a Ppk of 1.67. Some tried to convert a diametrical tolerance zone into coordinate tolerances but that was just wrong. The North American automotive suppliers spent a lot of $$ for showboating with no value added.
Dave D.
www.qmsi.ca
I don't know your what drives your desire to statistically tolerance.
Are your tolerances too small for your supplier to achieve the PPM defective levels expected "with specified limits"?
Are your suppliers disregarding the "variable portion of tolerance" in their capability predictions?
If you can get your suppliers data you can plug it into one of these two spreadsheets (PpkMMC if only size and Ø position deviation data) or (PpkMMCXY if size and coordinate deviation data). The later is more powerful since you can examine potential capability based on mean shifts to both the feature size and the independent coordinates given their demonstrated sample variations.
If you are considering specifying statistical limits with their targeted conformance ppm defective levels in a negotiated resolution with a supplier... you can use these spreadsheets to observe their potential capabilities with respect to the variable limit tolerances.
Dave,
We have been over this many times... I disagree! Enabling reliable prediction is very powerful economically. The difference between continuous and discreet variation control and conformance prediction is day and night.
My concern is mostly that I should be able to audit a supplier and know when the supplier has a solid understanding of design requirements, proper process control, and appropriate inspection and data collection. (I am a designer, but I have significant input into QC activities, where I work.) Also, I struggle to apply tolerances that are appropriate to my designs, I need feedback from the QC data to improve my designs.
I have been looking into software that compares the CAD model to point clouds and reports how well a part conforms to the design. (SmartProfile, GeoMagic, PolyWorks, VeriSurf) I am guessing that they would somehow quantify HOW WELL a feature with bonus tolerance met the spec'. It would be interesting to see if all those software packages evaluated the feature the same way. Regardless of the answer to that, how can any of them claim that it is possible to give a number? (Maybe your presentation will clarify that, Paul.)
Peter Truitt
Minnesota
If I can comment your presentation, I see one - IMO very significant - simplification in your approach. Your data seems not to include effect of perpendicularity error of an axis of a hole relative to planar datum A. On page#5 you are showing hole axis as a point, which for me automatically means that you assumed it to be perfectly perpendicular to datum A. Do you think it is always true? Then on page#7 you are presenting X,Y deviations as a single pair of numbers for each sample, which in fact won't be a case if axes of the holes are out of squarness relative to A.
What I am trying to say is that if I had to do any statistical calculations, predictions or whatsoever on position at MMC (regardless if this is practical or not), I would rather invoke boundary (virtual condition) interpretation into play. Just like Don described in one of his tips:
In the most comfortable situation (time resources) I would hit some points of hole surface at one level along 'z' axis the part, then repeat it on one or two levels more and try to check how far the points are from theoretically exact position of the hole. The smallest of the distances would be a size of related actual mating envelope (RAME) of the hole. Radial difference between RAME size and virtual condition size would tell me how far I was from the spec. limit. Repeating the probing routine on bigger population of parts (holes) would give me continuous data that I could easily work with.
Good analysis relative to perpendicularity and remember that the round hole may not be perfectly round which would affect the results. If the hole is long then one should also measure the centre distance to confirm that straightness is not a factor so, in fact, one should measure the top, middle and bottom of the angle.
Some people who tried capability where there was a diametrical tolerance zone of 0.5 mm or .020" just converted it to a coordinate tolerance of +/- 0.25 or +/- .010 which is wrong.
I have had this discussion many times with Paul that I came out with some thoughts at http://www.qmsi.ca/capabilityindex.html
Dave D.
www.qmsi.ca
Your objection to the analysis procedure is... that it does not confirm that the maximum material boundary is not violated when only a sampling of the feature's surface is used to generate data about its size and location... specifically disregarding its possible orientation deviation. Did I get that right?
So what!
Say that I have to demonstrate that my processes are capable to 1.67 Cpk before I am able to sell any product. If I use attribute gages I would have to demonstrate that less than 1 part in a million defective.
I could say that, as I was producing those parts that I am hopefully confident that my process is...
1.0 capable if it had no defects in 740.8 parts
1.33 capable if - no defects in 31574.39 pieces
1.67 capable if - no defects in 3488555.79 pieces
Of course I would probably need another instance of a defect at a similar interval to establish some marginal confidence that my prediction is valid.
My point is demonstrating predictive conformance with attribute gages is counterproductive and very expensive in terms of product required, gage purchase, gage maintenance, and scrap if defects are detected with moderate sample frequencies.
Let me say that...
All inspections are estimations and all inspections make assumptions to some extent... even the hard attribute gages aside (I refuse to call them functional until I verify that the tolerance modifiers were indeed specified according to the feature's function).
With hard gages there are all sorts of problems that I have witnessed but a few that come to mind are details that enter the features before datum surfaces are contacted, incomplete pattern engagement, non-unified datum mobility allowance among feature patterns and most common worn gages.
With layout or dedicated bench variables inspection the assumptions are numerous and to the untrained, inexperienced inspector their application is seldom noticed. A trained inspector can examine the process, the fixturing, the sequence, the tooling method, and all other details, identify its strengths and vulnerabilities and adjust his assumptions to aggressively scrutinize vulnerabilities and abbreviate scrutiny of its strengths. He is aware of jaw squeeze, closely related features accomplished in separate operations, etc. To most others, engineer's, designer's, and the like the assumptions they employ when they inspect are transparent... ignorance is bliss.
With coordinate measuring machines in the hands of a programmer who is inexperienced and has never done layout inspection the assumptions are legion! Dangerous I might add. Does anyone question form when reading the size on a CMM inspection report? Only those aware of how many points were gathered, how may sample planes chosen, what algorithms were used... not to mention what should and should not be aggressively scrutinized or abbreviated according to the process vulnerabilities. Once again in the hands of an inexperienced or untrained inspector like engineer's, designer's, and the like... ignorance is bliss.
So all of these inspection methods have their weaknesses including the hard attribute gages... If I was checking a bore and I suspected that it was particularly vulnerable to an orientation deviation according to the observed process and I wanted always to use its "related actual mating envelope" in my variable limit position tolerance capability calculations... and I had not yet programmed that routine in my software... I just might move reference to one end of hole rotate orthogonal to the hole's specified orientation, collect three eight point circles top, middle, and bottom, then use all 24 point's X and Y values stripping off the Z (depth) values to figure a 2D maximum inscribed circle size and location to use in my capability equation.
The point is that it is not the tool that is the problem it is the unmerited assumptions used in the inspection process, the lack of attention to sources of process variation, and the lack of understanding of the tools available that make for poor process prediction and subsequent optimization.
You go ahead and use your attribute gages... I want to know what variation I have so I can either ignore it or fix it so that I can ignore it or continuously manage it for my customer's benefit.
Paul
BTW... It is better to use both the related actual mating envelope size and its position separately in the continuous data capability equation rather than combining them in the resultant condition and comparing them to the virtual condition as is suggested in the Tec-Ease example. They are independent sources of variation and should be analyzed as such.
Most secondary and tertiary datums are holes and if those holes are referenced at MMC, achieving variable data on the features may not be 100% valid. We could have a pattern of slots at MMC referencing secondary and tertiary datum holes also at MMC. Love to see the variable data in that situation.
If one wanted to proceed with a capability study of the centre of a hole using coordinate tolerancing, no problem but positional with a diametrical tolerance zone at MMC referencing datums at MMC, the data collected may be suspect.
Dave D.
www.qmsi.ca
I did not say anywhere in my previous post that I would like to use hard (functional) gages or see them as the only reasonable solution in checking position at MMC. I will keep insisting that method presented by Don Day is heading into good direction. By defining proper measurement routine CMM can be utilized quite nicely to gather all necessary continuous data for further capability study. It would require some work, but IMO it is absolutely possible.
I agree with you that the size of a feature and its position are two different and independent things, however Don's example is only showing how to do a capability study on position tolerance at MMC callout using 'virtual condition boundary' approach without taking feature's size variation under consideration. And it may be a case when customer or somebody else is only interested in statistical verification of feature's ability to assembly. It would not make much sense to check statistically the size of the feature since the violation of its virtual condition is critical for this function. Verifying size of a feature (size of unrelated actual mating envelope) would require different probing procedure (at least having in mind what are the definitions of related and unrelated AME in Y14.5-2009).
Again I agree - all inspections are estimations and assumptions - we are not living in a perfect world, inspectors are not perfectly qualified etc., however disregarding feature's orientation relative to datum reference frame can lead to serious issues in some cases. If part is relatively thin, then, yes, you could omit it because perpendicularity error would be like almost nothing in 90% of situations. But if the part is thick, perpendicularity error might be significant and for sure I would not assume feature's axis as a single point with unique X, Y coordinates.
I agree with you! Forgive me for the flippant comment "You go ahead..."
The point of my presentation was to demonstrate how to perform a variable limit tolerance statistical conformance prediction. It does not delve into the related-unrelated size issues... that was not the point of the presentation. It does show how to examine the potential of both constant and variable limit geometric tolerance data.
I will agree with you as well that Don's [virtual- Mean(resultant)]/3* sigma-hat(resultant) will give a prediction of the variable limit tolerance... but I do not agree that it is heading in a good direction because the actual variation of the processes generating the RAME and its location can be amplified or masked by using them "as oombined" in the resultant diameter variation. There is a better way!
Paul
Peter Truitt
Minnesota
The un-oriented actual mating envelope represents the size that the largest pin or smallest sleeve that fits the feature... It is the never perfectly square to the datum features. Its size cannot correctly be used for these calculations because it ignores orientation to the datum features. I call this the
The oriented actual mating envelope represents the size that the largest pin or smallest sleeve that fits the feature while perfectly oriented to the datum features. It is never perfectly located from the datum features. I call this the Related-AME.
The resultant condition is the boundary produced by the size (RAME) and its geometric location deviation from the specified basic location/orientation.
The combination I am talking about is the later two RAME and location deviation.
RAME is a new term on 2009 standard, short for Related Actual Mating Envelope, there is another term UAME means Unrelated Actual Mating Envelope, you may get some idea from the tip here.
http://www.tec-ease.com/gdt-tips-view.php?q=77
SeasonLee
I would disagree with your interpretation of RAME. Here's what Y14.5-2009 is saying on related actual mating envelope: "a similar perfect feature counterpart expanded within an internal feature(s) or contracted about external feature(s) while constrained either in orientation or location or both to the applicable datum(s).
Taking example of from your presentation RAME is perfectly oriented relative to datum A and perfectly located from datums B and C.
The operative words here are either, or, or... I am using orientation only in describing the "oriented actual mating envelope" to describe the size that I would use in the variable limit tolerance analysis.
It seems as though some of you folks or an ASME technical group should consider writing ONE publication that is unified where possible but carefully explains the disagreements with workarounds or guidance that might significantly mitigate problems applying and measuring bonus tolerance. (It sounds as if the disagreements are minor or non-existent once the words have been completely beat into submission.) It might also recommend best practices for organizations using bonus tolerance based on their production volumes or level of regulation/safety.
The 'best practices' for using bonus tolerance in my organization is my concern: I want to use the proper hieroglyphics on my drawings and be able to explain exactly what they mean. Most folks would agree that if it can't be measured, I might as well leave the design to everyone's imagination. The general concept of bonus tolerance is clear, but the application of the concept through the organization and into the supply chain is not. I do have some experience with measurement uncertainty and measurement bias and that makes me concerned. Based on what I have heard so far, knowing my skills and the skills of the suppliers I work with, knowing the production volumes we see, and knowing our quality budget, I do not see an appropriate use of bonus tolerance in my organization. I will, at least, urge my colleagues to ask our suppliers to demonstrate their method of calculating bonus tolerance to measure their competence, if they want to use bonus tolerance.
I would also be interested to hear an answer to a related question that I had earlier: I have been looking into software that compares the CAD model to point clouds and reports how well a part conforms to the design. (SmartProfile, GeoMagic, PolyWorks, VeriSurf) I am guessing that they would, somehow, quantify HOW WELL a feature with bonus tolerance met the spec'. It would be interesting to see if all those software packages evaluate the feature the same way. Does anyone have experience with these programs?
Peter Truitt
Minnesota
You stated, "I do not see an appropriate use of bonus tolerance in my organization. I will, at least, urge my colleagues to ask our suppliers to demonstrate their method of calculating bonus tolerance to measure their competence, if they want to use bonus tolerance."
The theory of bonus tolerance allows for more usable parts and fewer rejects, if it is something like a clearance assembly. I would hesitate to scuttle those benefits simply because the statistical monitoring is difficult!
I'm not saying that I have a solution or could explain it better than the above posts. But golly, don't abandon the concept of MMC unless there is a real-world physical reason to do so.
John-Paul Belanger
No doubt I am getting into another sticky-wicket, but composite profile callouts for holes/shafts make sense to me for most situations where I might otherwise use bonus tolerance: Assuming equal-bilateral tolerances for size and form, the means of the inner and outer boundaries of form and size coincide, making it possible to stack the histogram for both on top of each other with the same mean. The CAD model can represent the nominal geometry at the mean, unlike bonus toleranced features, which seem to have a fuzzy nominal geometry. Nominal CAD geometry with coinciding size and form would increase the chances for successful and lean CAM and better Cpk, I would think. Stack-ups are definitely simpler and less error-prone. The form allows much of the same shift that bonus tolerance does, allowing more shift within the form as the size increases. One can reasonably argue that a design might allow more tolerance using bonus tolerance, but I am thinking that that depends on the specific design or specific manufacturing methods. When the nominal size does not fall at the mean of the virtual and resultant boundaries, the amount of available tolerance is not as effectively used. (Like the difference between square and round tolerance zones.) Profile form boundaries can easily maintain wall thickness. Plug gages can still be used to measure holes and a single-axis measuring stick to go from the plug gage to the edge of the part can glean the form, if nothing better fits the quality budget. I think that I would have the same measurement uncertainty and bias as I would have if I used bonus tolerance without statistically and painstakingly maintaining the physical size / virtual axis relationship and a staff of GD&T lawyers. Nevertheless, I see the suppliers looked stunned when I bring this up. (Not unlike a few years ago when we saw our first GD&T call-outs.) So far, I just back off and give them size and position. The stuff I am presently working on actually seldom benefits from bonus tolerance because of all of the press fits and similar design situations.
Thanks, everyone for this very valuable discussion.
Peter Truitt
Minnesota
