Modelling of existing RC beams
I would like to ask if we can modell reinforced concrete beam elements using column elements instead of beam elements when assessing existing structures? The reason i am asking this is because in beam elements we can not give details in shear reinforcement (links) as it can be done for column elements. Thanks
RE: Modelling of existing RC beams
I would say yes, but no better thing than try. If you do, please share if you find something wrong about.
Yet in such case specify the stiffness reduction of the (separated by label) beams that are modeled as columns as explained in Help for
Frame - Property Modifiers
Otherwise you may end with some wrong stiffness.
