Opening an IGES file with ANSY
I try to open my .iges file to made CFD FLOTRAN simulation but i can import it.
the error message is allway the same :
"An unexpected error ( SIG$SEGV ) has occured... ANSYS internal data has been corrupted. ANSYS is unable to recover and will terminate.
Previously saved files are unaffected."
I don't undertand, normally it's very easy ..
Thank you for any help.
RE: Opening an IGES file with ANSY
But the size are completly different between solidworks and ANSYS, 210mm become 7.7 in ansys. So all my result are false.
I don't know how i can change the dimansion.
I need your help.
Thank you
www.priamengineering.co.uk
Thank you very much PriamEngineering
