Rendering window closes
Hi all,
I'm trying to render a model using photoview 360 which is now a add-on in SW 2011.
About half way through the rendering process, the render window closes for some reason. There's no warnings or errors, it just closes. Anyone got a explanation of what going on.
PC Spec:
SW 2011
P4 Chip
3Gb Ram
RE: Rendering window closes
My guess is your running out of memory.  Try rendering a smaller image (640 x 480 maybe or something similar)at a render quality setting of good and see if that completes.  If it does then you can keep increasing the size/quality until it fails.  Then you'll know your systems limit.
Rob Rodriguez CSWP
www.axiscadsolutions.com
www.robrodriguez.com
www.swugn.org  www.nvtswug.com
SW 2011 SP 3.0
Hi rockguy,
I've been reducing the image size, but no luck. I had to borrow a rendering program of a friend to do it. Now it's finished.
