CMU Wall Design
CMU Wall Design
I am working on a project that has an interior CMU wall system that is supporting 12" deep steel joists spaced on 24" centers for a mezzanine floor. These walls intersect into other CMU walls that do not support joists. As suc, the elevations are established. The joists ends are to bear on embed steel plates. The question is whether the embed plates are to be flush with the CMU or raise the plates out of the CMU by say 1/4" to avoid any direct contact of the joist ends with masonry? Any thoughts or design guidance document recommendations would be appreciated.
RE: CMU Wall Design
I hope that helps.
Structural Design Engineer
New York, NY
RE: CMU Wall Design
