What can I do?
What can I do?
Hi everybody,
I have a problem, Please I need some help :)
As you could see in the image attached, there is a solid and a circle black drawn. This circle is indicating a extrusion made from the base until the horizontal cylinder. Everything is ok but as you could see, there is a line created after the extrusion and this line appears also in the drafting. There is a way to erase this line in the drafting?
Thanks in advance for any reply.
RE: What can I do?
RE: What can I do?
Thanks so much =)
RE: What can I do?
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
RE: What can I do?
Thanks a lot for your kindness, I have attached the file. I tip to avoid this issue would be great.
Regards.
RE: What can I do?
Note that it's constructed using a few less features and with sketches which are better constrained (it appears that you create your sketches with very few geometric constraints, as if you've turned off the auto-constraints and then you add only the ones that you think are needed). Anyway, take a look and see what you think.
John R. Baker, P.E.
Industry Sector
Cypress, CA
RE: What can I do?
