SW Assembly and Part file updates
It there a simple way to mass update/save all our old SolidWorks files to the newest version without opening, rebuilding, and then re-saving them?
I ask because the sustaining engineering department at the company I work for feels that some of the issues/errors they encounter, when opening some of our SW assemblies that have old parts, occur because the part hasn't been updated to the newest version.
RE: SW Assembly and Part file updates
Use the Start > All Programs > SolidWorks 2011 > SolidWorks Tools > SolidWorks Task Scheduler > Convert Files application.
Conversion can be slow, and will tie up a computer, so run it overnight, or over the weekend, or on as as needed basis. Depends on quantity of documents. You could also use several computers to convert different directories.
Thanks for the help!
