Pressure Gauges?
Pressure Gauges?
I read the FM Global Code 7-32, and there is a rule regarding pressure gauges to reduce leakage to a minimum:
"Use restricted orifices in piping connecting the gauges to the equipment."
Would this juste be a needle valve? Or is it referring to some other device?
Gabriel
Gabriel
RE: Pressure Gauges?
TTFN
Chinese prisoner wins Nobel Peace Prize
Stonecold
A pressure gauge snubber as suggested by Stonecold.that screwed into the connection will do the job.Snubber are commonly used for dampening out fluctuating pressure.Available off the shell.
