Finding Underconstrained Int. Sketches Identified Using Checkmate (NX6
Longtime lurker, first time poster here with a NX question.
We are currently are trying to get a part to pass checkmate.  Checkmate has identified a few sketches that are not fully constrained.  I was able to locate all but 2 using information> expression> list by sketch.
Is there an easy way to search for which internal sketch is associated with which feature?
Thanks!
RE: Finding Underconstrained Int. Sketches Identified Using Checkmate (NX6
Not at the moment.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Thanks for the response John.  Do you have any idea if this is something Siemens PLM is looking at?
It's been requested, but I'm not aware of any project currently underway to provide that sort of feedback.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Below is a simple journal that lists sketch info.  It may be a starting point to give you what you want.
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.Features
Module NXJournal
 Sub Main()
  Dim s As Session = Session.GetSession()
  Dim ui As UI = ui.GetUI()
  Dim lw As ListingWindow = s.ListingWindow
  lw.Open()
  For Each sk As Sketch In s.Parts.Work.Sketches
   sk.Highlight()
   lw.WriteLine(sk.Name & " (" & sk.ToString() & ")")
   lw.WriteLine(" IsInternal: " & sk.IsInternal)
   If sk.IsInternal = True Then
    lw.WriteLine("   Parent(s)")
    For Each feat As Feature In sk.Feature.GetParents
     lw.WriteLine("     " & feat.GetFeatureName.ToString)
    Next
   End If
   lw.WriteLine(" IsActive?: " & sk.IsActive)
   lw.WriteLine(" IsBlanked?: " & sk.IsBlanked)
   lw.WriteLine(" Color: " & sk.Color)
   lw.WriteLine(" Layer: " & sk.Layer)
   lw.WriteLine(" Font: " & sk.LineFont)
   lw.WriteLine(" Width: " & sk.LineWidth)
   lw.WriteLine(" Objects:")
   Dim objects() As NXObject = sk.GetAllGeometry()
   For Each obj As NXObject In objects
    lw.WriteLine("  " & obj.Name)
   Next
   If sk.IsInternal = False And sk.IsBlanked = False Then
    ui.NXMessageBox.Show("Information", _
    NXMessageBox.DialogType.Information, _
    "Sketch " & sk.Name & " is highlighted")
    sk.Unhighlight()
   ElseIf sk.IsBlanked = True Then
    "Sketch " & sk.Name & " is blanked")
   ElseIf sk.IsInternal = True Then
   "Sketch " & sk.Name & " is internal")
   End If
  Next
 End Sub
End Module
Hope this is of some help.
Frank Swinkels
A small addition to the previous journal to find the sketches that are not fully constrained.  Each sketch must first be  activated in turn. We can then get the number of degrees of freedom remaining.  If the DOFs are > 0 then the sketch is not fully constrained.  Finally we need to deactivate the sketch.
Dim dofs As Integer
Dim status1 As Sketch.Status
sk.Activate(Nothing)
status1 = sk.GetStatus(dofs)
If dofs > 0 Then
 lw.WriteLine(sk.Name & " has " & dofs.ToString & _
  " degrees of   freedom")
End If
sk.Deactivate(Nothing, Nothing)
Hope this helps
Frank Swinkels
