MV/LV Transformer output
I have a configuration with 3 MV/LV transformers: 2 working and 1 standby with an auto-transfer scheme(I attached a single line diagram)
http://files.engineering.com/getfile.aspx?folder=e062394a-d37e-480e-a04a-715eb5e58a41&file=SLD1.bmp
- In normal operation, buscouplers 1 and 2 are open
- Standby transformer can feed either busbar 1 or 2 (interlocks)
i.e When the standby transformer is working it feeds only one side, through buscoupler (CB).
- Distance between transformers and busbar : ~ 20m
- applicable code: IEC
I'm asking if in this case if an additionnal CB at the standby transformer output is necessary or not?
Please advise.
RE: MV/LV Transformer output
@BENSAID: I feel there is no requirement for an additional CB at the standby transformer output.
Case 1: Stand by transformer is feeding the left side via Buscoupler 1. In case there is a bus fault, tripping of buscoupler 1 breaker (and the incoming side breaker) will isolate the transformer. Same is the case with stand by transformer feeding the right side via buscoupler 2 breaker. In this case, tripping of buscoupler 2 breaker will isolate the transformer from the fault.
Case 2: In case there is a transformer fault, then tripping of buscoupler breakers 1/2 will isolate the fault from the healthy bus.
Bus-coupler breakers itself act as standby transformer breaker.
Are there any loads on the centre bus section?
Are the incomers and bus couplers breakers or motor operated switches only?
thanks for your replies.
ScottyUK : there is no load on the centre bus section
jghrist : breakers motor operated
