Assembly total weight
I've an assembly with sub-assembly and one component.
The sub-assembly is as reference and exclude from the Model reference set.
The total weight of the assembly is the sum of the sub-assembly and the component although the sub-assembly is exclude from the reference set and treaty as reference component.
Where I wrong or solution so the total weight is the only of the NBR component ?
Thank you...
Using NX 7.0.1.7 MP3 and TC8.1
