Pipe rack estimate
Pipe rack estimate
Friends,
Can anyone give a general thumbrule for the following Pipe rack query which came to my mind while doing a proposal,
(1) Which is costlier, a single layer pipe rack with greater width or a multi layer pipe rack with less width.
Thanks in advance for your replies,
BK
BK
RE: Pipe rack estimate
The single layer is more costly.
Reasons:
1.) Real estate, even in the plant has a value and the single layer will use more real estate.
2.) Structural Beam, The single layer will require a heavier beam to span the longer distance and carry the total load of all the lines.
Thanks again !!
BK
It's much more expensive for your client at the end destination (field costs are always higher), but if you're doing the proposal and trying to win a job, and there are no specifications to how modular it needs to be....just a thought.
Let your acquaintances be many, but your advisors one in a thousand' ... Book of Ecclesiasticus
