Bracing Steel Beam Bottom Flange with Light-gage Stud
Cold-formed trusses at 4'-0" on center are bearing on a wide-flange beam. There will be a steel roof deck diaphragm at the top of the trusses. Can I use a light-gage stud, say 3-5/8", 16 Gage, as a kicker from the bottom flange of the beam to the bottom flange of the truss to brace the beam for uplift and torsion? Is there a better detail?
RE: Bracing Steel Beam Bottom Flange with Light-gage Stud
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
