SWX sheet format into Draftsight
I have used DwgEditor (DE) a few times when someone wanted a dwg file modified. I just found out that it is not bundled with SWX 2011. DraftSight (DS) seems so easy to use because it is similar to both DE and SWX. I would like to have the title block, rev. block etc., on a drawing template Is there an easy way to use our SWX sheet formats / drawing templates as a drawing template in DS? Would making a block of the SWX sheet and inserting it into DS be appropriate?
Thanks in advance.
Geekman25
Thanks in advance.
Geekman25
RE: SWX sheet format into Draftsight
That will suffice for now. I will have to learn some more about this and then try to create a DS template which uses the attributes of blocks so the "custom properties" of the dwg are quickly editable.
Geekman25
http
Maybe they will make this available for download.
See also http://ww
