Query in Mechanical Engineering Design book
Hi all,
I am using Mechancial Engineering Design by Shigley/Mischke Sixth Edition. I noticed on page 367, there is an equation with the parameter "Su" ('S' subscript 'u'), however, I can not find the definition of "Su". Is this supposed to be the same as "Su" ('S' subscript 'ut' which is ultimate tensile strength?
RE: Query in Mechanical Engineering Design book
Is this supposed to be the same as "Sut" ('S' subscript 'ut') which is defined as the ultimate tensile strength in the book?
-Dustin
Professional Engineer
Pretty good with SolidWorks
