Solidworks/DWG Editor Programmers in San Antonio Area
Is there anyone looking for some side work to write a program for use in Solidworks DWG editor?
We are looking to automate some of our processes and looking for some programming help. We make a product that comes on a string and needs to be laid out at different spacing's and lengths depending on the customer's enclosure. We currently have a spread sheet that gives our manual layout person the guidelines. If we could bring the product size into DWG editor is there any way to automate the locations of our products?
I am wondering if this might be an application for DriveWorks but things are only really only done in 2D. We are more concerned with the spacing between product in a line and then from line to line.
RE: Solidworks/DWG Editor Programmers in San Antonio Area
Can you not create the automation in SW and output to whatever 2D format is needed
I did not realize it had been replaced. We are running 2011 but almost never open the 2D stuff outside of solidowks.
Our customer's enclosures are usually pretty free form and the work is currently done manually using Adobe Illustrator. We are thinking of changing over to the 2D package for SW since we have extra licenses for that and I am under the impression it could also be controlled using VB similar to Solidworks.
There are many people in the San Antonia area. I suggest you start a thread at https://forum.solidworks.com/ asking for contract assistance. You are able to post an email address there, but site management here does not want emails posted.
If you do post in the SolidWorks forum, please post a link here so that others here can respond.
