Preparation for GDTP Technologist certification exam
I would like to take the GDTP Tecnologist certification exam. I need your guidence for preparing to the exam. Can anyone suggest me how to prepare for the exams?
I have purchased the following books for the reference
1) ASME Y14.5M-1994
2) Fundamentals of GD&T by Alex krulikowski
3) Advanced concepts of GD&T by Alex krulikowski
Some one told me to study entire ASME Y14.5M-1994 standard. I have a question here, in the ASME Y14.5M 1994 standard they are so many other standards refered, example: for Screw threads it is ANSI Y 14.6, for Surface texture it is ANSI Y14.36 etc.,
Do I need to study these ANSI standards as well to prepare for GDTP certification exam? If so where can I get these std., or is there any book which I can refer?
Please suggest me and do the needful.
Thank you.
RE: Preparation for GDTP Technologist certification exam
Look to ASME Y14.5.2-2000. This is the document that defines all the requirements for GDTP Senior and Technologist certification exam.
Most of the requirements are based on Y14.5M-1994 standard, but it is very likely that in the near future this will change to Y14.5-2009. As far as I know from ASME (Matthew Carnino) the decision is going to be made this year.
Madhu454, When I took the test I just reviewed ASME Y14.5M - 2009 as well as other good books I had that were based on the standard.
Drstrole
Yes, you need to know ASME Y14.5M-1994 pretty much cover to cover.  The test does not cover the other standards referenced in Y14.5.
Keep in mind that the test covers more than just GD&T.  So many people forget the little stuff such as definitions, rules for plus/minus usage, how to dimension a radius, etc.
Certainly look at Y14.5.2 -- it has a checklist of every topic that you'll need to know.
John-Paul Belanger
Geometric Learning Systems
Hi All,
 Thanks a lot for your guidence. Will be troubling you with more questions in future :)
Madhusudhan
