Assembly Constraints
When deleting a component I get the following message ...
"Some deleted components were positioned by assembly constraints.
Do you want those constraints to be deleted as well?"
I always select YES, so is there a setting that will prevent the question from displaying ?
NX 6.0.5.3 (NX 8 Beta)
Windows XP32
RE: Assembly Constraints
I always select YES also.  Can anyone explain why anyone would ever want to keep the (newly) invalid constraints?
Proud Member of the Reality-Based Community..
capn,  I guess you could always go back in and redefine those exact constraints to a new component.  I just delete them as well when I delete a component.
Fighter Pilot
Manufacturing Engineer
Yes, that option allows a user, whose next operation may be adding a replacement Component, to reuse the old Assembly Constraints as best he can.
While some people may consider that to be a rather obtuse workflow since they could have used the 'Replace Component' option instead, with the 'Maintain Relationships' option toggled ON, there are some people who prefer to work using separate and explicit operations rather than trying to peform all the tasks in a single action, since at one time that's the way UG/NX worked and some people just prefer to continue to work in that manner and so this Constraint 'message' and the options it presents, was our attempt to accommodate these customers.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
John,
So I'm guessing there is no customer default to control the message then ?
Windows XP32
