E-house distance from hazardous area
Hi just wanted to learn if what other standards aside from API-505 and CEC section 18 that will tell us allowable distance of electrical building from hazardous area in canada? are there other standards? basically problem is that electrical building is planned to be installed 15feet away from a pressure transmitter in an industrial facility, as per API-505 if building is away more than 10 feet then it should be ok. Is there such other standard that is different from this or usually just a client preference? thanks!!
