Acrobat.Help me?
Acrobat.Help me?
hi
I have a problem out of Cad. I have a form by *.pdf format how can I add text to this file . I try to use Free Text Tool ( short cut is S) but it have border line of texts. I do not want this border , so do you have any way to show this problem.
Thanks you very much
RE: Acrobat.Help me?
You say "out of Cad" I suppose you mean not in a cad program. Are you using "Adobe" to add to someone else's form (which would be a PDF)?
Most software uses forms and boxes in similar ways.
With forms, you sometimes see the outline of the input field until you enter the information and go to the next field.
Also, the box containing the field may have properies set which give it a border. Look into the properties and try to find the setting. Often you will see that the default is a particular type of border but one of the choices should be no border.
Hope that this helps a bit.
