Reservoir oil tank baffle design
Any help or ref much appreciated. I did a search for existing threads but not much was there. I am looking for any info, references, or suggestions when designing baffles that go inside a reservoir oil tank that can be used to help prevent trapped air from entering the supply line.
The situation is a reservoir tank with a supply line at the bottom and return line at the top. This is a non pressurized tank. The pump is sucking oil from the supply line to an engine then loops thru a cooler, filter and then makes its way back to the tank. It is a square tank that will hold an oil volume of 40 gallons.
Thanks.
Thanks.
RE: Reservoir oil tank baffle design
reason to use baffle plates in an oil tank can be:
-structural integrity of the tank
-prevent oil from slushing back and forth (ships)
-allow solids to settle out
construction details:
-scallops in corner of tank, connecting the compartments
-suction on 1st compartment, return on last compartment
h
or this:
http:/
Ted
Aeration of the reservoir oil can be mostly eliminated by use of de-aeration devices such as swirl tanks or centrifuges. However, these devices normally require a scavenge pump, since they are located in the return flow. Here's an example of a swirl tank:
http://www.tedecoindustrial.com/how.gif
If your system has no scavenge pump, your best option is to make sure that the oil volume turnover rate is as low as possible. Sometimes a screen mesh divider placed mid-level across the tank will help to discourage air bubbles migrating downward.
hope that helps
terry
