Ansys Workbench Constraints Help
Hello, I want to ask about contraints Ansys WB. My problem is ; Contsraint region is'not free at -Z direction, But It's free at +Z.And X,Y free. Thank you.
RE: Ansys Workbench Constraints Help
Can I write constraint equation?
You could try a Body-Ground Joint and setup Stops.
Sounds like a "Compression Only" constraint could work.
It is non-linear, but should work.
