linear compressed air feed system
I have 20+ carriages on a single 3m gantry that require electrical and pneumatic power. I'll be using main PLC to control slave PLC on each carriage using industrial WIFI signal. I can get the power to each carriage using conductor rails (street car idea) but how can I get compressed air. I don't have room for 20+ cat tracks so I'm looking for a something that can be attached to the carriage linearly... One idea was to purchase a rodless cylinder with extra pistons and port them. Would anyone know of any other product out there for this job?
Pete
Pete
RE: linear compressed air feed system
The trick is, the loops have to be long enough that the tee runs are oriented normal to the track, not parallel to it.
Mike Halloran
Pembroke Pines, FL, USA
unfortunately that won't work as all except for one carriage can be working on one side and then you'll need 3m long loop. It's the same reason why I went with the conductor rails idea for electrical power...
Pete
Mike Halloran
each carriage is ~3" wide, this is a long gantry with many small carriages that must accelerate extremely fast plus to plan is to run low voltage to achieve the required motion
Pete
I'm guessing you'll need more than one because of the effective axial length of the seals.
Because of the extra seal band length required to go over all the pistons, you can't just add pistons to a generic cylinder, so you'll have to work with the factory, or buy an extra long cylinder to shorten and hack.
Mike Halloran
A rodless cylinder working as an interim reservoir could work, what kind of stroke do you need to accomodate? Not sure I understand why you don't have room for a festooned airline if there would be sufficient room for a rodless cylinder ???
You might consider a separate air line to each carriage guided by something like an IGUS e-chain.
h
My point was that the sealing strip rides out and back a bit from its normal plane over 4 or so rollers within the linear cylinder's piston assembly, so you'd need an extra long strip to seal multiple pistons. I don't think it's a generic material that you can buy in bulk, so you'd need the cylinder mfgr to make it for you. If they're going to that much trouble, I'd ask them to also drill and install multiple piston assemblies. That way you can buy the thing as an assembly and just bolt it to your carriages.
Mike Halloran
