Cohesive surfaces working, cohesive elements not working?!
Hello everyone...
I posted an issue I was having with cohesive elements in a simple 2D 4 point flexural analysis a few weeks ago. Since then I have changed my model to cohesive surfaces, but due to the shocking slow speed of cohesive surfaces I am back with Cohesive Elements.
I have included my model to help with the problem I am having. (Zipped due to size - 5MB uncompressed)
I am looking at the delamination of a simple beam in bending. The beam has in effect two notches on the tensile surface (modelling a laminated material with a cut lamina on the tensile side). In my experimental work the tesile surface is the location of the delamination.
For some reason the cohesive elements are not working however!
I dont want to make this post too long, but am not sure how much detail to include!
I have tried:
- Using viscous regularisation for the cohesive elements (usually 1e-5).
- Making the cohesive elements about 10 times smaller than the shell elements I am using to model the beam.
- Turning on reduced intergarion as I have been told I may have shear locking effects going on.
- I have turned ON non-linear stabilization.
The problem is relatively simple and takes about 5 minutes to get to the point where it does not fail.
Sorry if this post is a ramble, but I am a little new to Abaqus, and FE in general.
I really appreciate your help with this stuff.
Thank you,
Rob Malkin
I have tried:
Thank you,
Rob Malkin
RE: Cohesive surfaces working, cohesive elements not working?!
Rob Stupplebeen
https://sites.google.com/site/robertkstupplebeen/
