Relay Instantaneous Element
Hi All,
I just want to clearup an issue I have being pondering for a little while.
Lets say you have a relay with the Instantaneous set at, say, 12000A for a CB rated at 1600A. Is it a situation where the Inst. picks up 12KA or higher, or is it at some value below 12KA?
RE: Relay Instantaneous Element
If you are talking about medium-voltage or high-voltage circuit breakers, the relay has no idea what the rating of the breaker is.
Generally, there will be a time overcurrent element in addition to the instantaneous.
David Castor
www.cvoes.com
The time delay relay pickup is most likely set at 1600A or below, depending on what the breaker is feeding.
