Hardox forming
Hardox forming
Hardox forming
I need to bend Hardox 500 to an angle of 35 deg. Material thickness is 30 mm, bending length is 75 mm. What would be the most econonmical bending method using a shop 200 ton press.
RE: Hardox forming
Here is a tip, go to the web site below
http://www.ssab.com/brands/hardox/
Find the Knowledge and Support tab, and inquire. I have used this function before and their technical folks are very helpful.
RE: Hardox forming
Thank you metengr,
I tried doing it as specified in the attachment, It always get cracked, Do you think I need to reheat it prior to bending it.
RE: Hardox forming
thwainy;
Contact the technical guys at Hardox based on the link I provided. They will help you.
RE: Hardox forming
Metengr,
Thanks so much, definitely will do that.
Regards.
