Gas lift pipeline pressure after cooling down
I have a 17 km gas lift pipeline (no water present in the gas as the gas has been dehydrated). It is at a temperature of 41 C and 220 barg.
The pipeline is closed in and then left until the temperature has cooled to seabed temperature of 8C. How do I work out what the new final pressure is?
Also, how do I work out what phase it will be (will it be all liquid phase or a mixture of gas and liquid)?
RE: Gas lift pipeline pressure after cooling down
Check boiling temperature of the specific gas at the new pressure. If boiling temperature at new pressure > 8C then liquid else vapor.
BT > 8C, partial liquid initially and may be full liquid if you leave it for sufficient length of time.
V,R,n will be constant so cancel out of the universal gas equation.
P1 - 220 barg
T1 - 41 C
Z1 - 0.7784
P2 - unknown to solve
T2 - 8 C
Z2 - ?
(if I use compressibility in equiation, do I not now have too many unknowns - i.e. two unknowns Z2 and P2 and only one equation?)
As Quark said, use Z(1) on both sides of the equation (so it falls out), calculate P(2), get the Z(2) that goes with P(2) and recalculate P(2). Now calculate the Z(2) for the second P(2) and see if it is close enough. Iterate until it is.
David
P2 = 163 barg
All vapour. Thanks for your help guys.
