Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This has been the MOST helpful forum that I have been a part of and I want to say thank you. The tips, tricks and helpful advice that you all contribute to have been lifesavers in many instances..."
Geography
gmh265 (Mechanical)
17 May 11 23:40
Hey Guys,
I have been tasked with replacing the damaged impellers of a group of water/slurry pumps that are used in the mining industry. They do see a fair bit of nasty fluids including sea water.
The impellers are currently cast iron, and the failure mode is the impeller blades wear away. I was thinking a replacement of 1020 steel fully machined, however I have little experience in material selection, particularly when it comes to corrosion.
What am I overlooking here?
Stainless is not an option unfortunately.
cheers,
Joel
KENAT (Mechanical)
18 May 11 0:09
Why were they cast - is it a shape that will be difficult/costly to machine?  (Though with modern multi axis machines that's a less common issue.)  Would your volumes now preclude casting as a cost effective solution?
What finish was used originally, and are there any new surface treatments that might be better?
Not quite the same requirement but take a look at thread330-295440: Strong, hardenable, corrosion resstant steel? for ideas.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
EdStainless (Materials)
18 May 11 8:54
Often they use Ni-Resist for cast pump impellers.  This is a high Ni cast iron that has very good corrosion resistance and fair wear resistance.
What is the original producer offering you? If they are worn then you can't reverse engineer the blade shape.
Fabricated impellers are usually difficult.  Even if you can get the geometry correct they tend to have issues with fatigue at welds.
You should not use a plain steel.  If you really want better life then you need to look at alloys like 3CR12 or other straight Cr stainless grades.
Plymouth Tube
MikeHalloran (Mechanical)
18 May 11 10:51
1020 is definitely not the hot setup.
You need to do some industrial archaeology.  Dig through the purchase records of the company until you find what material was originally specified for the pumps, and whatever was specified for the previous set of impellers.
You will probably find that the extant impellers are not generic 'cast iron', but a high tech abrasion resistant alloy that costs even more than stainless steel.
Whatever it is, work from there.
Mike Halloran
Pembroke Pines, FL, USA
rmw (Mechanical)
18 May 11 21:30
Nagle Pumps had a 28% Chrome hard iron impeller material that they used for slurry and mining pumps.  Pretty doggoned tough stuff.  I remember one nationally recognized pump repair company at a loss of what to do with it because they had never seen a CI impeller that hard.
rmw
Pumpsonly (Mechanical)
23 May 11 5:28
So your pumps see some thing more than just water..
Warman pumps used Ni-hard for their slurry pumps.
strider6 (Materials)
24 May 11 2:24
I agree that carbon steel is not an option and you should go at least to the Ni resist, or improve to higher alloy, but you should define better what you mean with "nasty fluid" if you want to make a  good material selection
http://corrosionist.blogspot.com/2010/10/selecting-pump-for-seawater-service.html
hope this help
S
Corrosion Control
clay87 (Mechanical)
25 May 11 21:58
Erosion or Corrosion is main problem?  You could always coat the impellers to improve the life of them.
Close Box
Join Eng-Tips® Today!
Join Us             Close
