Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...If there has ever been a justification needed for access to the net during working hours, just referring to this site should suffice. Fantastic!..."
Geography
jesselai23 (Chemical)
17 May 11 16:45
I have a stream flowing at 400F, 1 atm.  hysys gives std liquid volume flow of 615 barrel/day.  So hysys calculates the 615 barrel/day base on 60F and 14.73psi, is that right? Thank you.
Helpful Member!  MortenA (Petroleum)
19 May 11 5:29
There are several different types of "standard flows" defined in HYSYS - so be carefull.
The trickiest one is the one where they state the flow if all components were condensed - and this was transferred to standard conditions - where this would be condensed - beat me?
Best regards
Morten
Helpful Member!  DarrenO (Chemical)
19 May 11 10:04
Also be wary of the fact that the standard conditions used will also change depending upon what temperature unit you are using to view your case.  When viewing in C or K the standard temperature used is 15C, when viewing temperature in F or R the standard temperature being used is 60F.
cloa (Petroleum)
22 May 11 23:54
If you have any other HYsys questions, please be aware its best placed  in the Aspentech Forum. http://www.eng-tips.com/threadminder.cfm?pid=137
Close Box
Join Eng-Tips® Today!
Join Us             Close
