concentrated load of edge of beam flange
I have a concentrated load of 5000 lb. on the edge of a beam.I am trying to calculate/estimate what localized effect it has on the beam flange. Torsion on the overall beam is low as per my calcs. But I want to verify that there is no localized stress or deflection concern in that limited area of the beam flange.
I looked at coefficients for loads on "plates" considering 3 edges "fixed" - 1 at the web,and the other 2 some distance away from the load foorprint and one free edge at the flange edge.
But that really isnt the actual situation as the "edges" perpendicular to the bean flange edge arent really fixed but just continuous. I looked at it also with 45 degree distribution thru the flange to the web and it's fine as far as bending stress. But even that is not really the actual condition.
Anyone ever check this condition? Is there some simplified way to verify that the local area of the flange is ok?
RE: concentrated load of edge of beam flange
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
We investigated a case where the entire top flange of a beam rotated because a plastic hinge had formed just below the bulb...
-5^2 = -25
http://www.eng-tips.com/supportus.cfm
