landslide - remedial work/preventive work
Anyone having some experience on how to remediate an area, which has shown some sloughing/landslide. Currently, the landslide has not yet extended to close a road. Any vurrent trends or techniques on how to reduce/relieve stresses causing the landslide ?
Water table is high at the crest of the slopes, indicating that it may be a problem. What is the fastest way to drain the water ? How to seal existing cracks so that it will not further causing progressive failures ?
RE: landslide - remedial work/preventive work
Rockjoint
rockjoint@yahoo.com
In complement you have to install a pumping system or some horizontal drains.
A network of horizontal drains will work.
Ideal solution will depend on site topography .
