Design of Shear wall with negative axial load
Dear colleagues:
I have a shear wall that has a Pu of -75K in what seems to be the controlling LC and a relatively low shear and moment in the order of 36k and 260'K respectively. Theoretically, this Pu is less than 0.35 Po and the other conditions set forth in section 1921.6.6.4 of UBC 97 for not providing a BZ are met. The total vertical reinforcement provided can easily resist that pure tension.
The code states only that Pu has to be less or equal to 0.35 Po, it does not specifically mention -at least to my knowledge- that Pu cannot be negative.
How would you interpret this? Thank you.
RE: Design of Shear wall with negative axial load
I find it surprising that you have a shear wall in pure tension.
