Lance (drum stinger) operated valve?
I am designing a small tank that will contain oil that will flush a drum lance (stinger), and it's associated pump and piping. I don't know if anyone even makes something that will do what I want, but I'm looking for a valve that will only open when the lance (1" stainless pipe) is pushed through the valve. In my mind I'm envisioning a swing check valve that has a spring to close it (the valve will be mounted 15° above horizontal). Does anyone know of such a valve? Thanks,
RE: Lance (drum stinger) operated valve?
Good luck,
Latexman
Good luck,
Latexman
Matt
