Pack and go Design table and equation references not adding suffix
I have an assembly that we build customized version of.  I used a design table to be able to customize the dwgs quickly and easily.  I saved that assembly, parts and dwgs in a Design folder and I use pack and go to put into a job folder so I can make any changes I want without affecting my template.  The problem is that I always add a suffix to give the parts a job number.  Solidworks pack and go does not update the equations or design table references that therefore I have to go in and manually change them.  Anyone have any suggestions?
thanks
Josh
