Help! NX5 trouble selecting Template Title Block
I have been playing with the drafting mode in NX5,
I inserted a template(or create sheet with template) but I don't know how to modify the title blocks. I tried to open the .prt file inside the template folder, but the same thing, I can't select nor modify the fixed lines and title block. I want to modify it because the A0 title block seemed a bit too small for me(I can easily modify the green text, but not the blue title blocks). Can someone provide me a step by step solution?
